As i was resetting my car's ECU i noticed a "missing" fuse. I checked on the back of the cover and it shows a fuse there. Where there a spaces for fuses it shows no fuse on the back of the cover.
With my car being an S i wondered if it could be for something in the Sport and SE that mine hasn't got.
Does anybody know what the fuse is for and indeed if it is missing?
The fuse is one of the big square ones in a group of four.
It says on the back of the cover:
H-LP
CLN
30A
I've had a look in the manual and cant find where or if it says what fuse it what.
Could somebody maybe have a quick look at their IS and see if you've got the fuse i'm on about??
On my car this fuse is present. Could it be a headlamp fuse for the HID's?
Thanks Mike. :D I was thinking it might be something that i haven't got on the S model. It looks like there might have been a fuse in there at some point because there is a slight discolouration on the pin that the fuse goes onto. Unless i'm tripping :duh:
Thanks Lee. :D
As you can see from my pics , they're different from Lee's sport also. But you can see on the cover that it shows a fuse, where as Lee's doesn't.
headlight cleaner ?
looks more like its a relay
H-LP
CLN could well be headlamp cleaner
Thanks Barrie :D
