Anyone Seen My ..
crazylex
On a spare pc at work that I am just trying to get going having reloaded XP PRO, the @ does not work.
So when you shift and press ' all you get is ' the shift works, because when you press shift / you get ?
Swapped keyboards and same thing.
As we all know life without an @ as tough these days.
If anyone has a spare @ they do not use I have cash waiting.
Seriously though, anyone got any ideas to try.
have you tried all the other buttons, do they work or even represent something else
mac`s swap the @ button with the " button
Sounds like the wrong keyboard driver, is the keyboard PS2?
Try "Control Panel" - "Keyboard" and look for a different driver
Yup, same as this, I know US and UK keyboards have different layouts.
If need the @ sign quickly you could always run charmap and copy it from there.
Try checking the control panel for all the regional and language options settings (especially under Languages tab -> Details -> the Default input language).
What do you get if you hold shift and press the number 2 key?
D.
D.
SHIFT 2 = @
interesting, whats that mean ?
D.
SHIFT 2 = @
Your system is in US keyboard mode (generally, the default when installing Windows operating systems). :sick:
IIRC, shift and the ' key should actually give you double quotes.
But anyway, to fix, do as I mentioned before - hunt for any mention of US and change it all to UK!
Should do the trick.
D.
D.
Sorted - exactley as you said - US settings.
Cheers buddy
Rich
