Brake Servos And Abs Sensors & Control Unit
IanF
Before I can get it registered, my Altezza needs to go through a comparison test with a UK spec IS200 (big thanks to Chris Javadude :D :D :D ) to demonstrate that brakes, seat belts and steering are the same.
The guy at the test centre recomended confirming that the brake servos and ABS units all have the same part numbers before the cars go in for testing.
Can anybody advise on where these are and what they look like.
Cheers
Ian
the is200 abs units have also changed through the years ;)
Bugger - why does everything have to be so complicated! Surely I'm due a bit of good luck sometime soon :duh: . I'll check out what bits are on mine.
Mat - do you mean the servos are different between IS and Altezza? Are they interchangable?
Thanks guys
Ian
Thanks guys
Ian
the brake servo is interchangable, the abs unit possibly is aswell
I've been looking at part numbers this afternoon, trying to identify bits that I suspect are critical to the brake system, and are therefore likely to be checked. I've identified these bits - anything else likely I've missed?
I've got the following part numbers
ABS Unit
Toyota 44540-53010
Denso 133200-5040
Servo
862-02508
0221
High pressure cylinder (not sure about the name or relevence of this bit)
0B11 (could be 0811)
B07 (could be 807)
How does all this compare with what's on the IS200?
Ian
