Sounds brilliant mate, hope all goes well :)
I've seen and used the john beams setup half dozen times at Elites facility in rainham,essex. Have to say its very impressive setup, i'm sure its the pure droool stuff for Tony :P
all sounds great Tony, all the best you know you can do what ever you want......
Mat.... you would not believe the information this machine will deliver......
How about for the 'Drifty' seeing...
The cradle symmetry over the tyres actual radius picturing the steering position during weight transfer and displaying the toe curve in the processes...... it will position roll centre and display the actual 'scrub radius' during any lock position, including bump steer and Delta curve..... and how is this for 'flash' if needs be any corrections at the chassis can be done 'live' without the wheel even on the car?.... the machine will image the angles via the brake disc!
.........n i c e B)
Not an empty post for view question.... when I'm up and going are you and the 'Drifty' willing to experiment with the advertised potential.... a visible proving ground for us both...... cost £0
of course, there will be much to learn......from all angles (ha ha you get it...angles) :winky:
Mat....... you rascal!..... i just laughed.... coughed.... spat out my fag, this bounced off the PC then landed on the cat! burned his arse, he then blamed the dog and bit her tail, she jumped up hit her head on the table and knocked over my beer!.........any Soldier knows this is sacrilidge.
On a real serious note, maybe if you are willing we can have a 'lock-in' and evolve 'testing' for the 'Drifty' if only to see how good the equipment is....
Have you seen the new 'Arago V3D' running!
yep sure deal mate, time is on our side though......which is good
This i assume is related to the 'driftys' current position in development?
Great news Tony :D
I'm so glad to see the dream becoming a reality :winky:
Good luck, you sure deserve it :D
Sorry about your Son's accident...... s*d the metal he is ok.... you have read it all!.... how come you are a 'no show' with the MX?.....and the ends....
