Yes Or No?
well, not 100% sure it's the bone yet.
Off to the quacks tomorrow to check.
Pain is in that region though, although not sore to touch, only when moving, kind of suspecting it's muscle related, but still want to get it checked out.
so everyones voting no? :D
just leaning over the same part in the engine for long enough makes my back legs ache a bit, im imaging that changing the manifold is not going to be a quick an easy job, so prob best to leave it to somewhen when your backs better, (time of with flu :winky: in a couple off weeks or so should do it )
u will also have to split the steering shaft at the universal joint, and also maybe best to remove the rear sensor to prevent any damage to the wiring, during manifold removal.
for the manifold itself there are 2 bolts that connect it to the rest of the system, these require access under the car
