Oil Cooler
BAGGY
Hi all thinking of running a oil cooler along with two gauges oil temp and oil pressure is there a way
of doing this using only one sandwich plate or is there any points on the block i can use.Has anyone
done this combination before?any help would be great.
if you are going to use a cooler, just use the sandwich plate
Oil cooler for sale in buy/sell section :D
Are there two take off's aswell as a inlet and outlet for the cooler?
No mate, just for the cooler, other menbers have had oil temp and oil presure taken from somewhere on the engine, i think matt or zee might know :D i know you can get the oil temp from using the sump plug.
my mistake , my sandwich has 2 take offs for gauges :blush:
ask dave ellen he will know
