Electric Mirror Not Working.
i cant tell u exactly which fuse - have you looked on the passenger and driver side kick panels
Yeh I've looked at the fuses in passenger and drivers side footwell as well as under the bonnet but I'm unable to locate the correct fuse.
I tried quite a few which I thought may be on the same circuit but all are ok.
So, if it turns out its not a fuse, what else should I look for ?
It appears that the mirror heating is working but just not the electric adjustable mirrors and the mirror folding motors.
what work was performed on your vehicle when it went to the garage??
The rear drivers side door had a new door skin fitted, the front drivers side door had a new moulding/bump strip fitted, also paint spraying on these bits. (using the Lexus approved bodyshop).
Nothing that should have effected the mirrors.
as they have been playing near the door area I would lift out the control panel on the door card ( locks,mirror et)c and check they have put the plug back in properly, just lift up the back of the control unit
