Toyota Starlet Gt Turbo
Bazza
Is that all! :D
you should easy have it done for JapShow Finale.
cant wait to see it go on the strip with the new mods, could we have a baby monster. :)
maybe :winky:
i thought the turbo would take a while to be shipped, turns out it was sent by airmail, and got here sooner than i thought :D
  • Replies 175
  • Created
  • Last Reply
Top Posters In This Topic
When i started reading it i was reaching for my wallet as i thought u were selling lol
Gonna be nice barry do u think you be bringin it to the speed trials ????
Tractions gonna be a massive issue with that much power.
Doddys puntos getting stripped down again soon so he should be hitting the 200hp mark hes just waiting on a mutsi turbo, id love to see u 2 battle it out at Pod :)
the latest update :
the transplant begins
as it was :
starting to strip !
its out :o
comparing the new (right) to the old, the red is not blood, its coolant :winky:
fitting together
its in :D
its a bit tight :o
filter fitted
well thats all i managed today, had a bit of a late start, and was knackered by the time it was dark
few runs and a few adjustments later
and.....it lives, :D
still quite a few more bits to go on, the oil cooler still hasnt arrived, hopefully it will give a bit more space, by relocating the oil filter to somwhere more assessible
Looking sweet barry, when will she be up and running ?
she is !!
all but for a bit of fine tuning she is a goer
awaiting the oil cooler, then strip down again and fit
then re mapping
off on hols on thursday so give it a couple of weeks :D
Will we be seeing her again up Pod on the 8th? :winky:
would like to say yes
but im not sure, there is running and there is running safely, getting the bit in the middle done might be tight to fit in before the 8th
but you never know :winky:
nice project and must be fun this little car what boost you hoping for mate have you you upgraded the fueling side
running at 1 bar
yep fuelling, uprated(supra)fuel pump, sard rrfr, currently controlled by e-manage, 330 injectors available if needed !
  • 4 weeks later...
a few developments
after seeing very high oil temperatures, is was necessary to get them cooler, the new turbo will help, but is was deemed necessary for a bit of cooling help
finally the oil cooler arrived
along with the filter relocator
and thermostatic divertor
a load of braided hose
and fittings
managed to find somewhere to put it all ! , its getting a bit tight in there now :o
after a lot of measuring, dismantling and cutting its in :D
have sore hands, that braided hose isnt very skin friendly :crybaby:
divertor is located behind the chassis bar
a little bit of tidying and tying up, and another job done
hopefully this will keep those oil temperatures down !
other developments
the turbo is having a new exhaust housing fabricated
this will allow the use of an external wastegate to allow more consistant boost levels
obviously nothings straight forward, in turn a new manifold is now being fabricated along with a new downpipe to accomodate the external wastegate :crybaby:
as they say, Rome wasnt built in a day :lol:
