Oem Brake Pads
GALLA_4
H Guys
I have been running Axxis pads for the last while but I am having a slight tapping sound at low speeds going in a straight line. This "tap" happens when I put my foot lightly on the brake pedal. I've tried the copper grease trick but that just made the noise go away for a about a month.
I am going to restore my brakes back to OEM spec as I feel these Axxis pads may not be a perfect fit. I used the shims from the old pads with the new Axxis pads and I think this is not ideal. I would like to restore like with like ie OEM pads and shims.
My question is what do I need to buy to "overhaul" the caliper?
When I order new front pads from Lexus will I purely just get the pads or do you get the shims and springs etc?
