i notice my sig is removed? i thought it was my comp, but aparently not? why has it been removed? and if i was told i may have been able to do somthing about it instead or reposting it all the time? :tomato:
ok the way i read it then i get a line for the image, a line for MyGarage and a line for the drink driving thingy which we were asked to support, with a return in between each? i make that 5 lines? or am i missing somthing, as mine seams no bigger than others with images?
Your image size was well over 468 x 60 pixels mate.
It was removed at least 3 times.
and the previous thread that Purvesh has highlighted was also bumped several times, as well as it being in the terms and conditions.
Hence why your signature image was removed, not because it exceed 6 lines.
no problem, as i sated i though it was my comp due to me doing stuff, that happened to coincide with it dissapearing, will sort it. am prtty new to the whole siggy thing
If your stuck with the image ............. just email it to me :
scarface AT metserve DOT com
and I will re-size it for you ! :)
