1993 Es300 Please Help !!!
nconaxk
I have the same problem bro. My needles are out. You gotta udnerstand that the needles cannot simply just be replaced. Those things are illuminated by some type of gas charge, and the cheapest I could find to get them FIXED was around $300....
You can either get a whole new assembly at a dealer: $600
Or get the needles fixed: $300 or so
Or get another speedo cluster at a salvage yard: $100 or so
Now, if you get a used cluster with the needles in good working order, the same thing will eventually happen to it.
Its VERY common in the 92-96 ES/Windom :( :(
