Battery Jump Start
Yes ok thanks. Any part of the frame or engine block is recommended. Want to be prepared for winter. Dont see any point in getting a new Battery as the one fitted is working fine for now. I would like to exercise my IIABDFI. (If It Aint Broke Dont Fix It) But doubts remain if car is not driven for 2 weeks in the coming winter conditions.
Because, if you're unlucky, you can fry the ECU or cause other damage.
It would be better to charge the Battery with it disconnected from the car.
If this will happen regularly, invest in a Battery conditioner that will trickle charge the Battery in situ.
