Manifold Replacement
Nick The Greek
if u have full access and the nuts/bolts come off easily and u have all the tools then say an hour or so - remember u have to split the steering shaft and there is no master spline so remember to mark it beforehand!
what u doing?
what u doing?
I want to cut and shut my precats when i'm fitting the s/c next weekend, i need to whip them off, run them to a garage and cut them cut out and new pipe welded in, hence am curious.
Or I just leave them in and get a racing manifold at a later date.
decisions decisions......
what u doing?
dont forget your balance pipe :tomato:
the stering shaft has a master spline on one end, but obviously not on the other. u remove the pinch bolt then tap the knuckle up the splines - give it a good soak with wd40/penetrating oil the night before to make it easier - same goes for the manifold nuts/bolts
balance pipe, whats that?  :duh:
I'm just concerned about them breaking down on me, clogging the main cat and going ka-boom.  :hehe:
got any secondhand cat-less manifolds lying around dave?
I've got one I could get chopped for you.
Got a proper manifold you can have as well :whistling:
the pipe will have to be mandrel bent if your having them replaced as the lower cat is curved.
Mine cost £65 all in from a company in Horton Kirby near brands hatch..
Call rob on 0780 805 5843
he did it in a few hours and was very good.
my record is 45 mins to remove and refit the manifold.......
maybe you could come over and remove mine this saturday then fargo :whistling:
then run it to an exhaust garage for me, get the precats replaced, then re-fit :whistling:
:D
THIS saturday you say,,,,,,, errr busy lol
