Spark Plugs
Diapason
Hmmm, but am I to assume that it wouldn't be subtle? As in, you'd definitely know there was something up?
Si
It would depend. If all 6 are crap then yes, you'd really notice. On the other hand if only 1 was breaking down a bit under load, the effects could be subtle.
They should be good for 60k and when mine were changed I couldn't tell any difference, but it depends on so many things like driving style, servicing, even the fuel. Only way to know really would be to change them.
Okay thanks. I was asking this in conjunction with my other thread about sluggish acceleration. I think I'm going to get a proper service done anyway, and I'll ask them to change the plugs. Car has only done 32,000 so I would have thought they'd be fine, but I might as well eradicate all doubt.
Si
I wouldn't change the plugs, maybe pull then out and have a look but they should be fine. If it's a sparking issue then more likely to be a coil pack but really the problem should be seen on the diagnostic equipment if it is to do with ignition.
