Metserve
lexus boy
Is anyone else getting this ?
I'm aware that a lot of the content here is linked form metserve.com but there shouldn't be any log in errors ?
Yep, I was getting it as well. I ran a spyware and virus check first which revealed nothing so I've got rid of it using a popup stopper (NoAds).
I can assure you this is not spyware / virus.
It seems to be that the new server does not like linking to images ... etc !
No problem. It's just that I didn't know that Metserve was anything to do with LOC so just to be on the safe side I ran the checks.
Is it particular areas?
I've not had it and been through quite a few of your previous posts with links on. I assume it's particular ones in certain folders?
Is the IUSR account set ok for the folders? You're not using challenge response only on the problem folders are you?
Update :
It would appear, that on the transfer of http://www.metserve.com
Some of the files transferred with errors, and were only showing up as being 0KB.
This had a knock on effect to LOC, as a lot of the images here (including my old banner) are linked from http://www.metserve.com .
I'm fixing this now, if anyone is still experiencing this problem, please say so here ... so I can identify what file has the error ! :crybaby:
Thanks.
