Brake Pedal Beeps
Jambo1977
Hello all,
I have a couple of issues with my IS200SE (V-Reg) and you guys seem to be pretty clued up with most things!
I've just changed my front pads, discs, and calipers, and have bled the system. With the engine off I notice that whenever I press the brake pedal I can hear 3 or 4 quiet beeps coming from the rear. I have never noticed this before, and don't know if its something i should be concerned about.
I hadnt used the car in a month and had neglected to turn the engine over every once in a while which resulted in a flat Battery. Yesterday I tried to start the engine but all i heard was a fast ticking noise. Guessed it was a flat Battery so arranged for a friend to come over to jump start it this evening. Noticed that when I turned the key there was nothing at all. Would it make any difference which key I was trying to use? When i was using the master key it was ticking over, but tonight when I used the spares there was nothing (I forgot my master key at work tonight!)
Dont know if these 2 are related in anyway...
Any thoughts?
Cheers!
