just a quick question.......
are you able to lock all the doors from the drivers door in the IS200 sport????
reason i'm asking is because i can't do it on mine and am not sure whether there's a fault, or the facility isn't in place.
cheers for any help,
rob
Yes you can .........
so i just flick the lock to the closed/open position and all doors should lock/unlock????
if thats the case, then any ideas why it wont do it on mine???
Are all the doors shut properly ? ......... could be a faulty button ........... ? Not sure really ! :blush:
if you mean from inside......no u cant, it locks all doors either from the key fob, or with the key in the door
? I think u mean the other way around .............. you can lock all the doors from the inside button !!
this is the situation.......
i can open/close all the doors with the key fob from outside and inside the car.
but, i wanna know if you can lock and unlock all the doors whilst driving the car (i.e if i flick the lever on the drivers door to unlock/lock it, should all the other doors unlock).
its got nothin to do with the key fob
There is a button on your (window button panel) that closes / opens all the doors !
yep that button you can...., but they ment from the rocker switch by the handle, which only locks that individual door
yep, you can lock/unlock all door's via the key fob or switch, on the driver door panel.
but if you try from the actual door lever, it will only open that particular door, not any other's.
so let me get this right, there's an actual switch/button on the driver's door that allows this central locking???
what's it look like???
i'm sounding stupid here i know, but i'm totally lost with this one
:blush: :P :blush:
what a $&%£$ i feel now!!! it was right under my nose and i just over-looked it!!!
cheers for pointing it out anyway!!
like you said yacoob, it happens!!!
.... and there's a big circley type thing to help you go around corners and everything.
Lexus are great for their gadgets.
:lol::lol::lol:
