Pictures (before and after would be ideal) of an IS200 SE with the TTE lowering springs (-30mm)
I would keep the standard shocks for a while - are they up to the job or are they going to bite the bullet after 10k?
Ta muchly :D
oh, and in answer to your questions (I have the Eibachs - which TTE rebadge and sell, same springs) mine was a SE..
You can read my thoughts on the thread link, but i had mine fitted 2 years ago and havent had any suspension or shocks issues..
just make sure you get your wheels aligned once the springs have bedded in...
Thanks for that mate - the PI's are tempting too now I have seen that they drop the car a little more. (-35mm as opposed to -30mm)
I don't want it to look too silly though - I am not planning on changing the wheels just yet so don't want tiny 17's buried in the arches - I don't think it would look right.
Also - has anyone fitted these themselves?
I have done front springs many a time on Peugeots in the past but the rear's are torsion bars so i've never had rear suspemsion out.
I assume (I haven't actually looked) that the top mounts are accessable from the boot?
Spring compresses, a full workshop and a pit are great things when you have them to hand :D :whistling:
it depends on what your doing with the exhaust as well - i think the standard box is okay - but if i have anyone in the back, speedbumps grate the backbox quite badly..
There are quite a few people fitted these themselves - Mat did a pictorial guide that's in the KB.
Not a difficult job, but a PITA and time consuming, especially the rears. Be a lot easier to do with a ramp or inspection pit.
BTW Neil (MacRS200) has the -35mm PI's fitted on his IS200
Sure have Mr M, and I am very happy with them too :D
I haqve 18" rims but this may help you as I opted fot the -30mm TTE Springs
BEFORE OEM SHOCKS WITH OEM SPRINGS
AFTER OEM SHOCKS WITH -30mm TTE SPRINGS
