Playing With The Coilover Stiff. Settings?
BernardTamHK
Errrr
Try it, you can answer all those questions yourself then :P
It simply adjusts the damping, soft tends to be like driving an American Yank Tank, Firmer gives you tighter damping.
Try it.
Errrr
Try it.
i knew that was comin .... i was just hopin to be a bit lazy and get an easy answer from the folks ...
its a bit difficult in hk to do testing .... cos its hard to find extended space where I can try differing manuevers .... and put into the mix the permutations of the varyin settings ... just makes it ten times as hard ...
so anyone gone ahead and done this before? ... im just curious ... has anyone tried setting the rear very soft and the front very stiff ... or vice versa?....
Yep i have.
I can turn mine on the spot from Soft to Firm and feel the difference just by pushing down the car!!!
You will instantly feel the difference.
Just get out there and try it!!! :P
