Purchased All This Audio Gear Today!
Guys what would you think of this setup below?. I already have the the headunit and this was making paste of the OEM speakers so hence the upgrade.
HEADUNIT
Max. output power (watts) MOSFET 4 x 60 Watt
DIN output power (DIN45324, +B=14.4 V) 4 x 36 Watt
Max. preout voltage (V / Ohms) 6.5 V
RCA Preout 3 (F + R + S/W)
REAR
6 x 9 - 3 way speaker
Peak power: 330 W
RMS power:110W
Voice coil: 4Ω
Sensitivity: 90dB
Frequency response: 35Hz - 22kHz
Mounting Depth: 81mm
Cut-Out Diameter: 150mm x 221mm
FRONT
6½" (160mm) 2-way component system.
CMMD. PlusOne.
Passive crossover.
90w RMS
270w max power
You can't do that.
Speakers come at certain impedance, your ones being 4ohms. There is no switch to flick, and you can't get 2ohm 6x9s, or 2ohm components (without spending some Wonga)
I hope you didn't buy the amp from the states... you'll be left high and dry if it breaks.... Diamonds often do.
Can someone help then! I am getting tired of looking through so many AMPs!! There is so many of them out there!
What Amp do I need to successfully power these Infinity speakers giving 100Wrms to each speaker and allowing for the 4Ω impedence of the speakers themselves???
Am I didn't buy from the USA! So thats not an issue!
