my steering wheel sits to the right but the car drives straight and I have absolutely no steering problem
It was caused by a meet with a roundabout kerb :crybaby:
Mate you need a geo anytime yesterday.
if you have a meeting with anything i.e pot hole or kerb
then a geom is paramount
just for picece of mind. after all tyres cost money :crying:
my geo is ok but the steering wheel is now sitting to the right.
It was 1.5 years ago.
'UPDATE'!
Since most of you that have met me know i work fo STS :duh: and i am not happy with this steering wheel topic. I have only been given a few reports regarding problem that i have, and another five from other companys that pm'd me, this is not enough to map a common reason.
Now i have to assume the problem this equipment i emailed STS and said 'unless this is sorted' i will 'NOT' support the Lexus geometry day! knowing this so far has cost them thousends..
Today:
The Calibration on the geometry machine was re-tested: passed
The Calibration program was re-tested : passed
The ramp was tested for level : passed
The Alloy hangers for the cameras were tested they : passed
The 'data' rod that measures the track was tested it :passed
The Radius plates ( car on bearings ) did show some concern, these are ment to be maintainence free...... so i wonder!!!!!!! they.......? :passed
WELL there is no more to test, of the 5% who have had the steering wheel off-line after the goemetry i have 'at this time' no answer why. good, bad, sad i dont know!
In veiw of todays efforts i will support the PR day since all measurments will be actual and a matter of 'fact'. WIM is back if needed :D 'STS' passed :D
suppose i should get my geometry done fairly sonn, had a few meetings with kerbs now, and wheel studs sheering.
my tseering wheel is to the the left...about an 1/8th of a turn but thats my fault not the cars.
Any pics of the wheels :crybaby:
Mine is also to the right. Or left? Dunno yet. But you know. What about this?
SteeringWheelOffCenterAdjustment: LINK
Thanks for that link, i will get to the bottom of this but at the moment i dont have enougth examples top map.
The only common area is movement of the castor position toward positive and then the toe recovery after, it would seem that even though the car is on radius plates this does not allow the upper parallelogram to move diagonally and to be fair why should it, this i can now understand or a least image but? why is the steering wheel always to the right? that i dont understand ( yet )
Hi Tony,
just wondering if you wanted me to send my results over? If it'll be of any help but I had my geom done on the 5th sept, the same day the ramps were tested.
Lee.
Hi Tony,
Lee.
Yes!.. the reason for this post is evident, of the 100's of Lexus's set 'why' has there been this SW off line RHD issue, As you know i have had every eliment tested and passed, from this thread other companies also have said they have the same problem. Supertracker explain my concerns have become more visible by the volume of Lexus's measured. But the initial issue still exists 'WHY'.... To be continued...
  • 6 years later...
Hi Tony,
I do apologise for bumping up a really old thread.
But I was wondering if you ever identified the cause of this "steering wheel off-center to the right" problem?
