Is that the MAF sensor sitting between the filter case and the throttle body?
Looks like you are drawing cold air from somewhere close to under the headlamp unit - is the corrugated air pipe insulated?
Notice much difference?
Hi Mike
1 Yes. It was the only place it would fit. Similar to the original position on the original airbox.
2 The pipe goes down to the grille
3 Yes I can feel the difference and it sounds more meaty. The car idles at lower revs too.
