`b` Position On Gearstick Rx400h
Does anyone know when (or why) the best time to stick the gear stick in the `B` position ?
I`m told it is for engine breaking and re-charges the batteries !
If you need to brake going down a hill, should you go into `B` mode aswell as use the brake to charge the batteries ??
Any ideas ??
Gazman :zee:
What I learned 'B' is for "hill climbing". A offroad gear. Dunno what it is called :blush:
It is for going up a hill and rolling down a hill :D While in B the engine is connected directly to the drivetrain and is used as a braking mass.
uhhh, dunno how to discribe it :D
So the brakes won't overheat AND the batteries are charged perfectly. It's more for rolling down a serpentine.
I was told it was for braking only - less wear on your brakes and it does of course recharge
java script:emoticon(':)')
You can actually drive in `B` mode - I wonder what that does to your engine / performance ???
Gazman :zee:
As I work for Lexus......
All B mode does is double the gearing to the electric motrs when in a 'trailing throttle' position - this increases the feel of 'engine breaking'.
Yes it will charge the Battery more quickly, but because you slow down quicker, you are charging for less time, hence no better off.
The only time you would use it is for long decents that required prelonged breaking - the B mode just allows the motors to take some of the strain off the discs and pads - just like keeping a manual in 3rd gear down a hill....
:ph34r:
