Front Fogs & Mot
blueblitzer
It wont fail
Front fogs are classed as an accessory and DO NOT have to work for M.O.T purposes.
Mine dont, and i got an M.O.T
Not as far as I understand it......if fog lights are fitted they have to be the correct colour and have to work.
Are any of the lawmen around to clarify this?
I stand corrected. This is what the MOT says about fog lights:
Rear Fog lamps
must be fitted to the centre or offside of the vehicle
tell-tale must work
must not be affected by other lamps and not be obscured
must be red.
i.e. Front fogs are not listed as something that is tested.
I have taken some advice from VOSA on this matter
If you have front fogs and they are CONNECTED they must work for an MOT
If they do not work DISCONNECT them and they will pass.
From the horses mouth.......
Ha!
So I was right! :D :D :D
Ha!
I knew you were, thousands didn't.....
Thanks alot for you help guys....Still a bit of contradiction.... :D
The guy at the MOT place said hed pass it anyway as i got my 4 tyres from him....
Is this not corruption??? :P
"THATS PANTS!!!!" for the MOT you need "side/dip / main and in the UK a osr "red" fog light....Think about it why! do we have "front" main beam.
Er, VOSA set the standards not me............
Besides, I've thought about it - whats your point on the main beam??
