Dashboard Warning Message
andy99
not wishing to state the obvious but, if it IS the gearbox then you could well have fried the overdrive, couldn't you, Mate?
Have you checked the levels? Gearboxes are a real pain in the A R S E unless its a long mount engine. (easier to get at...)
Bon Chance, Mon Amis
Loz
  • 3 months later...
Dont know if you resolved this from October but the O/D flashing is the diagnostics warning you there is an issue with the autobox (the O/D is integral on the Soarer box).
This can be as simple as a loose plug on the box or a failed sensor, the Soarer has a complex on-board diagnostic system, see my site for info on running the diagnostic routines - SoarerTT
If you have any fault codes you will need to get back to me for interpretation.
London Bill - Soarer 2.5 Twin Turbo
