Sports And Prestige Induction Kit
On the sports and prestige site does anyone have or know if the JCP is200 induction kit for £170 is any good? good bargin? sounds good? etc.
Also are there any others out there for a is200.
Just got paid so gotta spend it while its hot :D
Cheers
Cheers
I bought one of there a few months back....comes with a TRD filter, and sounds nice and deep when accelerating.....wouldnt say it improved performance though :)
There isn't really a wide choice of induction kits available for the IS200 ..........
True.....the main one that everone seems tohave is the TRUST kit, although I dont really like the look of the filter that comes with it. :yack:
You can always buy another filter ......... and just sell the one that comes with it :D
Yeah i read a review on 4 big filter companys with tests done , blitz apexi hks or k"n and some other. the only good one was the apexi the others where rubish let in loads of carbon etc ill try and find it.
Whats the best filter ppl would recommend
Cheers
Cheers
Found it. Was on one of the reviews on the prolex website http://www.mkiv.com/techarticles/filters_test/2/
Read it and see if you'll be buying a apexi filter this weekend hehehehe.
Only bad bit is the sound does anyone know how quite the apexi is ?????
Well, I have the K&N Typhoon,
http://www.lexusownersclub.co.uk/forum/ind...topic=23437&hl=
However I may even change the filter it's self ......... because it let in too much oil , and this goes onto the MAF sensor thus giving false readings .........
I don't think the IS200 have a MAF though, so that may not cause a problem ...........
The IS has a MAP so measures pressure rather than flow rate so should not be a problem. The only thing is if the filter is "over oiled" it won't let in as much air as it could which kind of defeats the object.
induction kit aint gonna do much for the is200.. just drop a panel filter in.... same results...
induction kit WITH cold air feed.......
or you could get a local shop to make you one up, think that's what i'm going to do and just buy the filter after.
Just wondering is this just me but the trust one in this picture http://www.lexusownersclub.co.uk/forum/ind...5&hl=greddy
is a bit ugly it cuts striaght across the engine and looks a bit thrown together.
Whereas this induction kit http://www.altezzasportsandprestige.com/Ai...uction_kits.htm
looks a lot better going around the engine and down into the slot.
What do you lot think ????????????????????
what picture? trust is a yellow mushroom
Sorry dont mean to be mean just think the other looks better :blush:
that's cool i didnt think you were?
for some reason all of your post didnt show up unless you edited it? thats why i said about the pics
i dont have it anymore but to be honest i think the top one LOOKS better than the bottom one.
What have you got now then i wanna get the one off of altezza but 170 with out VAT or P+P bit pricy?
I haven't got one at all, standard airbox back on.
and yes for what it is I think thats pricey.
save up and get a supercharger or just get a panel filter and spend the cash on something else
The Trust one would be the best, since the filter is in a place where it will get colder air and the pipe is pretty straight.
The Injen one on the other hand is probably not a good idea, since it takes a long bendy route round the engine, and in one place goes directly above the exhaust manifold (not good for cold air!). To top it off the filter ends up directly behind the radiator where it will get nothing but warm air anyway.
Go for the Trust kit and then buy a different filter if you don't like the look of it.
it wouldn't matter on a stock engine, it is more for aesthetics and accoustics than any significant power gain, it's a bit pointless buying a freeflowing filter/induction kit with the hope of increasing performance with a stock head. I would get one just for the induction roar, but it uglyfies the engine a bit too much.
OK, I drive an IS3, but are you trying to tell me that K&N are telling porkies with their claim of 8.5bhp with the Typhoon on the IS3?
It looks and sounds the Mutt's and is my beast engine mod so far....
I didnt do the test - the car they used was a skyline so the hp gains were a lot higher than the is would be. but from that test it does look like kn aint as good as others out there.
