Well im doing the Sat nav unit conversion for the 7" lcd screen -
question is which screen, what do i have to look out for??
i dont realy want to spend ££££ on it as i am probably getting rid of the car at end of year
so what is a good pixel number as they vary soooo much.
only want a single imput but 2 may be a good idea.
as for a dvd player i am going to do a temporary solution using a din sized player with a build in FM modulator from TG incar until i upgrade the whole audio system
are the ones from TG incar worth the money - £99.99
TG In Car
Specification:
- HIGH 336,900 DOT RESOLUTION
- REMOTE CONTROL
- AV LEADS INCLUDED
- GREAT VIEWING ANGLES ,UNLIKE SOME
- PAL/NTSC SYSTEM
- COMPATIBLE WITH PS2 , XBOX ETC.
- 2 VIDEO INPUTS
- 12V car power
- 16:9 RATIO
- BUILT IN SPEAKER
- HEADPHONE SOCKET
- MONITOR FOR IN CAR OR OTHER USE
- HEADREST BRACKET AND FREE STAND MOUNTS
Price: £99.99
come on, someones gotta know a little about what to buy?
i suppose RGB as an entry level connection
but idealy it will be hooked up to a MINI MAC at some point but dont want to go touch screen
Chris, I may be wrong but I think both those screens you have linked to have s-video/composite input only - not RGB which is what you need for a Mini Mac.
I use a Xenarc 7" TFT which is touchscreen, has 2 composite inputs and one RGB. They cost around £250.
A cheaper option would be this:
http://linitx.com/product_info.php?cPath=6...03a34e5ded3800c
£139 inc VAT
These have had good reviews and seem better then the Lilliput screens alot of people have had trouble with. It is not touchscreen - but you said you didn't want touchscreen.
cheers for that!!!
just wondering how much of the touch screen you lost tho within the housing. as after a quick measure up it looks like it has a larger screen than the maximum opening would allow?
or am i looking at the wrong bit?
cheers for any help, im a great belever in the measure twice cut once theory
cheers for that!!!
You are right - the housing is about 50mm smaller. I managed to (using a stanley knife) cut the bottom of the housing frame out to make sure I didn't loose any screen! :D
