:huh: Over the past couple of weeks I've found oil on the drive where I park my rx300 (mark 2), I;ve checked the engine oil plus the other oil which I can check using the dip stick (any one know what this is, auto gear box or power steering), any ideas where it could be coming from, also the engine makes a wining when at parking speed and/or hard turning lock. Any ideas before I take it to the dealers.
:whistling: if it is a mk11 rx300 then it aint that old, so me thinks it is just coming out yer air con, a bit of the old condensate when you switch the engine off.
