Scrapping Noise Take Two!
RED-EYE
Hey guys and girls,
i have got my new 19inch wheels on and since then a srapping sound has been coming from the rear discs and pads as i have looked at the sheilds and body work and nothing seems to be scrapping,
any idea's????
if its the discs and pad how much is it to replace them!!!!
cheers
stu
:crybaby::crybaby:
p.s. the noise is pxxxxxg me off!
Sounds like either your calipers are seized...
Take them off, use lots of WD-40 pump them and push the piston back with a g-clamp... repeat the process few times..
Pass..
Also... check the handbrake cable and also the cylinders could be faulty..
If u have warranty have it checked out.
Any garage can fix it though
Pass..
ok mate ill let you know how i get on thank you very much for the advise mate!
:D
