Is200 80k Service
well my 80k service is due on the car, but as me car hasn't been serviced at Lexus up until now i don't see the point of taking it there to be done.
A friend of the family is going to do it at a resonable price, i just need to know what is included in the 80k service as i want to ensure that it is done correctly.
Im sure one of you knows what is included! :D
Many Thanks,
Jason :P
Well, soon as I get change dude. I can remember it does include a new battery for the FOB! :P
i had my 80k done 2wks ago, just under £400, it included
ON RAMP
replace engine oil
replace oil filter
replace coolant
check transmission oil
inspect exhaust
inspect fuel tank
replace diff oil
inspect drive shaft boots
check front & rear suspension
check brake and clutch system pipes & hoses
check & report on brake pads & discs
check & report tyre tread depth
check torque stettings of wheel nuts
OFF RAMP
inspect air filter
check coolant level, strength, all hoses
inspect clutch fluid
inspect brake fluid
check pwr steering fluid
check drive belts for wear & deflection
inspect charcoal canister
check wipers, top up fluid
check brake pedal freeplay, check handbrake travel
check steering wheel freeplay, linkage for wear & security
replace Battery in remote (they didn't do mine as it 'tested ok')
check alarm, power window, moonroof, central locking for correct operation.
check all lights for damage, correct operation alignment-report as necessary
replace aircon filter
chek seatbelts, airbag covers (including side airbags)
check body for abrasions, damage or corrosion perforation - report as necessary
the bill included:-
service 216.00
engine oil 41.79
diff oil 9.81
enviroment protection charge 3.95
consumables 5.00
screenwash 0.83
coolant 14.92
pollen filter 37.62
drain plug gasket 0.76
oil filter 7.39
they reported 'stone chip in windscreen, n/s/f tyre close to wear limit on inner edge, spare tyre close to wear limit on inner edge (i need a geometry done, but cannot find anywear in s.wales!)
