Removal Of Sport Spoiler
Im trying to remove the standard sport spoiler as I have a new one to fit. I have removed the 3 nuts from inside the boot lid lining but its well stuck. I think its maybe been stuck in place with that double sided 3m rubber stuff they use. Is there such a thing as a release agent for the adhesive they use?
I need to get it off without breaking it as a replacement one is a bit pricey and I dont want to prize it off as it will damage the paintwork.
Your best bet woud be to use a heat gun or hair dryer. That should soften up the sticky stuff, then you should be able to carefully peel it off. Once it comes off, use meths or a similar remover to get rid of the left over crud it leaves.
