Oil Filter
:angry:  :angry:
How you supposed to change the filter on an IS200?
It must be in the single most awkward place I have ever seen :excl:
Any tips? :question:
oil filter ratchet.... take the under belly pan off and its easy to get at...lol
I looked at taking the pan off........... even took out a few studs but decided it would not be of any great advantage............ I'll have another look so :blush:
:angry:  :angry:
I've done a couple of oil and filter changes on my IS200 , read on....
1) jack up front of car , put on axle stands.
2) Remove under belly pan, this includes the 4" splash trim each side under the front.
3 ) Once under bell pan off, the oil filter is mounting on N/S of engine, up over the alloy engine mounting and also in line with the crossmember, its mounted in a very tight spot, once undone, remove old filter from back side of cross member.
3), before fitting new oil filter ,top up filter with new engine oil, let the level drop then top up again.( reason for doing this is help get full oil pressure on first start up , old motor trade trick !).
4) Fit new filter ,try to keep it up right , untill you screw it on .
5) Undo drain plug and drain out oil, ( if still hot , TAKE CARE ! )
if your buying your filter from Toyota/Lexus dealer , ask for a new drain plug seal.
6 )The rest of the job is like any other car, tighten filter, double check sump plug, refit under belly pan, add engine oil, start and run engine keep an eye on dash oil light, turn back off ,top up oil to correct level.......job done , just saved yourself a small fortune and have the satisfaction the the jobs been done correctly.
Bob .
Posted Today, 04:04 PM
  This type of oil filter remover ,is the best one to use on the IS200 , as its in a tight space ,a spanner can be put on the tool, instead of a ratchet
Where do you get this tool from?
:D
:D
Draper tools do one
Try Here search for stock no 37871. £12.90 for 1 :D
The one shown is from Screwfix,
http://www.screwfix.com/app/sfd/sea/search...=1&cd=1&x=8&y=6
The one i own is made by Sykes-Pickavant, tools used in the motor trade...
http://www.sptools.co.uk/
If you want the best one for the job, look up on auto express site ,they do a tool test.
:D
one example :)
Yes, that ones idea Bazza :winky:
Cheers guys .............. all I need to do now is find an online store that will ship to Ireland.......... :mat:
Surly you must have a local car accessory shop that can sell you an oil filter remover ?
Halfords
i purchased the one that fits over the filter like a cap and it worked perfectly
the company i work for sells the three legged version
www.tvh.be
i also purchased one off the company for £5.00 but i gave this one to my
Brother as he does various cars so better for him to fit a varid amount of oil filters
any one know where you can get non genuine Pollen filter from under glove box
Cheers Matt
