Brake Advice
hi, does anyone know of a way to see if the brake pads need replacing. im pretty sure the front pads needs replacing as i can hear a faint grinding noise when i brake hard but im not sure about the back. cheers
There are various means used to warn you that the pads are low:
1: indicator wires fitted onto the nsf/osr pads that activate when the pads are low and warn you on the dash
2: a float in the brake fluid reservoir detecting a drop in the fluid and warns you on the dash
3: a vibrating audible peg fitted on the pads that should send you a distressing sound that will send you to the shop
but the golden rule is if in doubt "check it out"
