Tyre Wear
Mr Morse
On the IS300, which tyres wear quicker - front or rear (under normal non-boy racer) driving?
I have done 8,500 miles, fronts have 7mm and rears 6mm tread.
Should I swap them over to get even wear? Rear to front diagonally?
Pirelli P-Zero Rosso 225 x 40 x 18 92Y
Leave them where thay are?? modern tyres adjust their profile according to load and weight disribution if you move the tyres front/ rear the handling can be impaired plus the tyre may distort, and i would say "never" change the tyres direction of rotation..
When you say the tyres are directional does that mean they are marked ( with an arrow ? ) to show which way they should turn, or does it mean once it's been on the car and gone clockwise keep it going clockwise?
Well there are three types
1: symmetrical: turn it/ move it/ rotate it (mark none)
2: directional/ arrow must point forward/ only move is axle to axle (mark arrow)
3: asymmetrical/ move only axle to axle (mark inside/outside)
Surely asmmetrical tyres can be moved left-to-right and front-to-back. You just need to ensure the tyre is mounted on the wheel the correct way round.
Blush.... yes: head down puppy eyes. dont forget two weeks ago i couldn't spell "tyre fitter" now i r one.
