Blue Print Adl Discs
neo boy
I got from my local auto store some Blue Print ADL front discs for my is200, this make any good?
As pads will need changing too so what brake pads shall i use? would it be ok to buy something like Mintex pads? as i not using Mintex discs would this combination of Blue print ADL + Mintex make pads waer out quicker or cause to discs to warp?
I know this is the case on OEM discs + EBC pads.
Alternatively should i stick to OEM toyota/lexus pads or Blue Print ADL ones?
Cheers
Cheers
ADL discs are the muts, but you must use ADL pads as well on any disc, the Mintex pads run to hot, the down side is the ADL pads have more metal in the mix so wear on the disc will be an issue.
Cheers
Blueprint -ADL is very good stuff, can be used if your car is still under warrenty.
Thanks for replies.
Considering going for Mintex then, not sure if i like the sound of 'too much metal' in the brake pad that causes them to wear...........
EBC is outta question heard EBC has very minimal brake dust though......
Thanks for replies.
Watch out for the "warp" Mintex run hot, soft is not always better?
Cheers
Do blue print not do pads to match their discs? If not and your after high performance pads, I can reccomend ferodo road/race(forget the exact model no.), or pagid(expensive , but the mutts nuts).
Mintex are reasonable if you buy the standard road pads, but they do make high performance pads that are much better
Cheers
Just use the Blueprint pads as well, very good and give out very little brake dust....if any B)
Brake disc ADT34387,
Pads.....ADT34291
also fit IS300 and GS300 up to 1997.
They have that wrong then. The pads on the IS are the same as the series II GS
I checked with Blueprint technical today, asked about pad number Blueprint ADT 34291,they cross referenced with OE part number, and fits....IS200, IS300, GS300,GS430 and SC430 .
Now that is as per original equipment pad,not aftermarket sports pads :) .
