I'm still getting the random brake light warning (footbrake flashes, then after 2mins all abs tcs etc.) come on .............brakes work normally? havnt tried the abs (for obvious reasons)....discs are well warped....could this start off warnings?....brake fluid stays the same and as i say brakes work perfect???
please any ideas before i take it to Lexus on weds :crybaby::crybaby::blush:
please, please rack some brains...............thanks with needs Will
Don't know whether anyone has mentioned this before, but it could be a dodgy wheel speed sensor.
I had one pack up (twice) on my old BMW causing similar symptoms. Also, it wouldn't change up into any gear over 3rd unless I shifted it manually which was a bit worrying first time it happened.
If you haven't done so already, its probably worth a trip to Lexus to get the fault codes read.
