A simple question for you I.T. guys perhaps
is there an easy way to check what IP numbers are in use on a network without having to ping each number one at a time?
maybe something that creates an IP map of the network?
im looking for something free or built into XP or Win 2k
thanks guys :)
thanks guys :)
Something like this http://www.angryziber.com/ipscan/ would do the job, or alternatively do a google search on 'ipscan'
Dave
If you have access to the routers you can network map much easier/quicker than a ip sweep.
Also if there are IDS devices on the network you may well generate alarms by sweeping.
Thanks for the tips guys
the only access I have to routers are netgear broadband routers
not the main system router
can I do the map from these?
No.
What are you trying to map?
At work we have a main server, and about 60 ports, but the ports are no longer in any order and some computers have been taken away and replaced over time, now there are some new computers coming that need setting up so i wanted to reuse the old ports without causing any IP conflicts.
I cannot add more ports as I dont have access to the main server and I wouldnt know how to add them even if i could, so I was just looking for an easy way to find what IP numbers i can use.
thanks for the help :)
The Arp cache contains a lookup containing MAC Addresses and IP addresses.
On Windows I think you run "arp -a" and on the Cisco kit it used to be "sh arp" I think
The command is built into Windows
If you run that command on the networking kit you would see all of the recently active devices.
If you've only got 60 devices on the network you're probably only running a single 24 bit subnet - just a thought but are all the clients using DHCP assigned addresses or are they configured to use Static IP's? When you do an "ipconfig /all" it will say DHCP Enabled true or false I think, can't remember the exact wording, its all simpler on the Mac :P
If you're using DHCP it wouldn't be a problem as the server would dish out an available address from the pool and lease it to the client temporarily...
Are all these boxes on the same site then?
download this software :-
http://www.inetcat.org/software/nbtscan1_5_1.zip
its called nbtscan, unzip it into c:\windows\system32
load a command prompt and type in the prompt
nbtscan 192.168.0.1-255
the above is an example using a class c 192.168.0.0 network, subsitute this with your ip range. or you could type
nbtscan 192.168.0.1/24
does the same thing, just less to type.
tell me if i'm being too techy.
Thanks I will give those apps a go :)
Aido they are all in the same site and are manually configured IP's
I wish they were DHCP would make my life so much easier hehe
Are they all on the same subnet then mate?
One thing to be wary of is that these ping scanners won't pick up machines with some personal firewall software if it is blocking ICMP echo's, it's a right pain in the arse!
I usually use Superscan and then go through the addresses it lists as free - if you get an IP conflict when you use an IP that's not responding you know you're hit one running firewall software :(
We use the Cisco VPN client at work and that is a bugger for enabling it's own firewall :(
yes they are all on same 10.0.1.XX subnet
its not a fancy network
but I seem to have ended up looking after it!!
thanks for the tips :)
Shouldn't do unless it is connected. What version are you running?
I tried the angry IP app and it worked a treat
very easy and clear to understand
thanks guys :)
always a mine of infomation :)
Ah that sounds about right as we're always VPN'd in - think it's v4.x of the client but not sure of the top of my head, it's the newer version for XP anyway....
Just used Superscan for the first time. It is good. Very quick too. :)
Careful matey, you'll have the network police after you!
