Turbo Installation
marcus
Hi guy just like to let you know im going to test fit the Custom manifold today. i will take some pic's as soon as :whistling:
I will all so be Fitting the oil cooler & intercooler today...........pic's to come :winky:
but i still have to make the custom intercooler pipe work........should not take to long to make i hope! :whistling:
I all so have to make a custom Turbo downpipe, so when i went to pick the pipe up for this i got a bit more to do a custom exhaust :whistling: :winky:
be back soon give you all the info on how it went.
  • Replies 145
  • Created
  • Last Reply
Top Posters In This Topic
Hi guys, Update on whats what i test fitted the manifold and all is ok :D
did not have a good time takeing the old manifold of as i had to undo the down pipe bit to get it out i had to cut all the nuts of and put new ones back as they had it ;) but all is ok now, just about to start the oilcooler and it started to ***** down :angry: so i had to call it aday.
I will fit the oilcooler on sunday now. :winky:
any way here are some pic's of the manifold
http://www.lexusownersclub.co.uk/forum/ind...&cmd=si&img=520
http://www.lexusownersclub.co.uk/forum/ind...&cmd=si&img=521
and here are some of Turbo in place :whistling:
http://www.lexusownersclub.co.uk/forum/ind...&cmd=si&img=522
http://www.lexusownersclub.co.uk/forum/ind...&cmd=si&img=523
http://www.lexusownersclub.co.uk/forum/ind...&cmd=si&img=524
:D Im Happy the way it all went today :whistling:
WOW!
Awsome stuff m8. :blush:
But that turbo can produce some lag I think. :unsure:
After lag you will feel a truck crashing in your back.... :whistling:
Oh... I killed my IS200T a bit today.
We damaged the fuel pressure regulator.
So the car hardly started and didn't even run any more.... DA*N! :angry:
Now I'm forced to rebuild it finally to a return-system then it should fly. :D
"UPDATE" i set out today to fit the oil cooler.
well to start of with i could not get the old oil-filter of :angry: but i got it of in the end, then when i went to fit the oil-filter adaptor that was ok untill i went to put the filter on..............i could not fit it as there was not much space, in the end up i had to take the adaptor of put the filter on the adaptor and then put it on as one :yawn:
then i had to put the cooler some where :crying: not alot of places i could put it as my cooler is the long one, so i put it just at the back of the RAD at the bottom and i have cut some vents into the uderbody :whistling: to get lots of cool air to it :)
i will try and get some pic,s in a day or 2
Marcus which oil cooler are you using, why not mount the oil cooler behind the upper grill like i have on the race car, the oil cooler on the Monster is mointed between the intercooler and the radiator, but the HKS coler is thin but tall.
a misconception about coolers is they have to be in the airflow, obviously this is ideal but not always needed. If u intend keeping the cooler where itis, can i suggest you make up some duting and channel some cool air to it
Hi matt, yea i was going to put behind the upper grill but the st/st hose i got was only 3ft 3" me thinking that would do it when i got them ;) i did try but the cooler i have is the long and fat one, so would not fit any way
i will keep it where it is and make some duting so i can get lots of cool air to it :winky:
Thanks any way matt for your in put :D
  • 4 weeks later...
I have just started to fit me Turbo.............just one :question: can some one post a pic of the intercooler pipeing that gos up past the fan & the ECU box ;) so standing looking at the car it would be the right side..............
