Fitting New Front Discs & Pads
squarehead
Thinking of changing my front discs & pads on my own (not with Pam :P )
Need a confidence boost - is it really easy (I can change a tyre, change my aircon filter, remove the stereo face to feed a PDA cable etc etc so I'm a little adventourous)...
So, can anybody really say that changing the discs & pads is really easy, I've read the forum and am convinced I can do it myself - not found the Knowledgebase though). I just fancy saving myself a load of wonga - the dealers are quoting £280 to do it.
Thanks in advance!
I changed mine on the IS was very easy, but I did have a problem undoing the bolts on the caliper. had to use a 3ft long breaker bar !!!
but after that. no problem, took around 2 hours to do both sides and I replaced the discs and pads. follow the advise above and you'll be fine.
you could take some photo's along the way and make a guide for others :)
Yeah I could take some photo's f*****g it up as I go along - Pistons, fuel reservoir, I think I'll leave it to the experts.
What if something goes wrong - Do I call the RAC !!!!!!!!!!!
Lol :D :D :D
Seriously, although ive never done it on my IS iI have sorted friends and families cars on a few occassions. Sure the principal is the same and I will be doing mine when the time comes. Just get amongst it!!!
If anything, Id much rather do the brakes than removing the head unit!! Wouldnt know hwere to start!! :crybaby:
Had a bit of good news with the discs today, decided to take it to Lexus Chester and have the discs & pads replaced. Turns out the discs were covered under warranty (car is 2 1/2 yrs old with 52k) so I didn't have to pay for them!!!
Only had to pay £37 for the pads - back of the net!
My next question is why did Lexus Stockport quote me £300 to replace them when Chester did it under warranty - any ideas ???? Opens a can of worms me thinks!
  • 1 month later...
I tried to do my own front discs but gave up after 90 mins when I couldn't budge the bolts holding the calipers on!! Boy them things are tight!!
My tip - make sure you've got a good spanner set and can get a decent length bar in there for extra leverage coz if you got a toy socket set like mine then those bolts might just beat ya!!
Anyway, I got a mechanic mate to do it - got all the good tools. He swapped front discs/pads and rear pads for a neat £50 - saved me the hastle and some money (compared to Lexus)
easiest way to get tight caliper bolts off is give them a saoak with wd40 for a few houras or even do it the night before doesn't matter if u get it on the disc and pads if you are changing them and on reassembly use some copper or aluminium slip
