Will this be ok? it'll only be for a couple of weeks
just one of guys didnt want to fit em till i was sure
so does anyone know
the car is for everyday use
so does anyone know
will be ok mate ,it will just look so silly and odd,will make you wheels lookeven smaller. :)
i dropped mine 30mm with 17's with a 40 profile tire and it scrapes on most speedbumps
take it easy with speedbumps and you should be ok!!
Must be some big speed bumps in your area!!
Mines on stock and dropped somewhere around 80mm. Tyres tucked about 0.5" upfront
oh yes
some very big ones
you can see the middle of some of the bumps has been torn away by other unlucky cars trying to drive over them
Im scared that one day I'll loose my hks hiper lol
N30jjb, i got an IS200 sprt n just wanted 2know when u lowered yours did u have 2 get ya arches rolled?
I have a set of 19's and am wanting 2 lower mine roughly bout 30mm :unsure:
Raddy,
if the offset is right, you won't need to touch your arch's :)
Mine's dropped about 60mm on 18x8 wheels. Never have any problems.
Think I'm only about 50mm on 18x7's and 18x8's and I catch everything round here, it's a pain in the ***** :(
Would have to check for sure but i think the wheels are 19'' x 7.5???
Have found a local body shop who will roll the arches for £20 per arch if needed, not a bad price to pay ......
Next problem is finding someone who can supply the lowering springs??
So far the only place i have found is Mo-Tech (£205 for 30mm drop)
7.5x19s is fine, you want 215/35/19" tyres, however 225/35/19s will also be fine with correct offset.
If your wheels have offset of 42mm front and rear you will be fine.
For lowering, contact ProLex for some Eibach -30mm springs.
Cheers mate,
had the tyres with the wheels in a package deal from South West Tyres, Clevedon
(215/35/19s)
Also had an email from Prolex this morning said they can sort us out a set of springs for bout £160.00
thanks for the info anyway :D
I got mine from AltezzaScott at Altezza Sports and Prestige. Or maybe try Prolex.
Bought a set of Eibach lowerin springs from Will in Aberdeen for £100 boxed in excellent condition .... bargain i reckon
Got a m8 to fit em 4 cheap in his garage when they arrive
Thanks for the help n advice anyway
