Rs200 Suspension
esi_vtec
i notice another Altezza 6speed mt with suspension looking slightly lower about 10+mm by guessing.whereas mine seems bit higher & mines a auto tiptronic. i heard someone saying Altezza RS200 has 10/15mm lower suspension than the uk spec is200 anyway with exception of sport that is 10/15mm lower anyway.
So does the Altezza Rs200 got different suspension depending if is an auto tiptronic or a 6sp manual?
if YES then is the 10/15mm lower springs a striaght swap possible without causing probs with the shocks & fits correctly?
i am pretty sure altezza is little lower than IS200s. driven both and the altezza was slightly firmer.
if you want to lower it, 10-15mm won't be noticeable.. go for atleast -40mm.
i went -80mm :whistling:
