Mot And Bulbs From Gb
whitie
I've taken the sidelights out and replaced them with the ones from the side -runner indicators
Reverse lights... I may change them over, I'll have to see if I can dig them out...
Also, I've taken the orange bits from the front indicators, can you get orange bulbs for these, or is it back out with the marker pen before it goes in? :P
I had trouble getting the bulbs for the front indicators when i took the lenses out, what i had to do was get a set of similar bulbs that wouldn't quite fit, and adjust the holder very slightly to get them to fit. It wasn't major work, and the bulbs were quite cheap, i got mine from the dealer in the end, as no-one else in norwich had any of them!
Basically all the difference was that on the clear bulb base there are two little extensions of the glass on opposing sides (basically like this 'dP') and the new ones had the extensions running all the way down each side. i just had to remove a sliver off the internal of the bulb holder to get them in, and they've never given me a problem.
Sounds weird, but if it helps, gis a shout!
Stu
