use wonder wheels? - beware!!
Rob
hi all, just a word of warning - if you use wonder wheels cleaner and you have had your brake discs replaced with the type that has a silver finish on the hub, BE VERY CAUTIOUS the cleaner will strip this finish off in seconds!!!!!! As i found out :o
rob
umm that would be a no, the area has already gone a bit rusty/tarnished! - As it has eventually stopped raining( after 36hrs!) im going to take the wheels off and repaint the drums while i can.
