Wireless Broadband Network Help Plz
LennyLexus
Hi Guys,
Just need a hand on getting the right gear to buy to set up a wireless network for TELEWEST/NLT broadband.
From waht i gather I need the products?
(This is to hook up the main computer next to cable modem to another PC around the house)
Option 1-Belkin
Belkin F5D7230uk4 54Mbps Wireless Broadband Router
Belkin F5D7050UK 54Mbps USB 2.0 Wireless G Adapter
1M CAT5e UTP Ethernet Patch Cable
Option 2-Linksys
Linksys WRT54G 54Mbps Wireless-G Broadband Router
My WebpageLinksys WUSB54G 54Mbps Wireless USB 2.0 Adapter
I have a LAN input on the back of my PC, will that be ok of installation?
Thanks in advance
That should be all you need although are you sure a 1m cable is long enough? Only cost a few pence more to get a 3m cable.
Also have a look at www.ebuyer.co.uk - may be cheaper. Make sure you include postage charges when comparing.
yep going for 1m because theres too much cabling at PC desk :angry: so it should be plenty. :unsure: Comes to £94 all in. I'll check ebuyer too.
only thing is cannot watch TV with it on in the same room..
why not? Are you using a video sender unit? If so try changing the channel being used on the the Linksys. Don't know what the default channel is - probably 1. Give channel 11 or 13 a go.
forgot to mention i am using wireless TV sender unit too... hate wires ;)
