Does Standard Is Have?
Maz
Guys does anyone know if the standard IS200 had a rear under brace fitted? i got the rear under brace from Matt C, and to be true, it is great, it improved the handling alots, the only problem is its so low, and there are more and more speed bumps where i live now, so i maybe taking it off, but was wonder if i need to replace the brace with the standard one (if there was one) if not then there no problems at all...hehe :whistling::whistling::whistling::whistling:
Tony,
There are two fitted as standard. I think you will need to refit them if you take Mats off.
Dave
it that mean it had brace at standard? i dont think i got them anymore, where and how much will they cost?
Tony,
Dave
I'd contact Chris Shipley he may be able to source them. They are 2 flimsy bits of metal so should not be too expensive.
