  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
this one is still in Japan, currently in auction for 1 Yen with 19 hours to go
1.00 Japan Yen = 0.00508135 GBP :)
at the most £800 shipping :shifty:
im after the engine, and wireing loom.........plus theres a few good bits on there to sell.
Rear spoiler
rear skirt
grill
dash
interior
1 side skirt :duh:
exhaust
and im sure some other fine items.......but who cares
Tell you what Mat, I'll give you 1 Yen for the console :P
well im putting a maximum bid of 200 € down........
the idea is to chuck the engine and loom into the race car, and turbocharge it
Then sell everything else off, anyone want to start putting dibs on the bits, before it arrives, obviously no money will need to be paid, till i know its on the boat.
so far the list is
TRD rear spoiler......................£200
TRD rear skirt........................ £100 (pete)
TRD grill.................................£50
Sounds good Mat, how much quicker would that be than the car is now?
Turbo sounds good though, just stick one of those turbo whistlers on there whilst you're waiting to get the turbo fitted and you're away!
The Race car stands at around 170hp at the moment (with the TTE re-map, and piggyback ecu), the altezza as std is 210.
so, as of now the power to weight ratio, make the race car at 170bhp, quicker than the s/c IS200.
so adding the 210 hp 2 litre 3s-ge will make it quite a bit quicker than the s/c cars, and its 0-60 will be pretty darn swift...........
so, then turbocharge it :)
Nice :)
So what weight do you reckon the race car will be at when you've got the Tezza engine and turbos in there?
Fancy doing a swap for a 'normal' car so you've got something new to play with ? Please :P
Saying that as soon as I get in the car the power to weight ratio is screwed anyway :lol:
Nice :)
the 3s-ge is lighter than the 1g-fe, so it will improve the power to weight ratio........
i think the car is around, 1250kilos at the mo, i recon i can keep around that weight, possibly even shave another 50kilo off with some further carefull trimming of none essential metal work and cabeling
Can't quite tell if its intack, but if so Drivers side headlight, and zaust if aftermarket :winky:
yep, ok, if intact
£20
I'm after the bit of trim that runs down the side of the windscreen (drive side) if its the same colour as mine (v light greyish)
not sure if its fluffy on this car, or smooth plastic, but they are the same colour.if you want them...£5 the pair
ill have the a/c panel please mat and the centre console surround that goes around the gear stick (holds the ashtray and fag lighter)
Mat depending on the condition of the Spoiler, i will be interested in it and also if possible can i have that Altezza Emblem?
