Went to buy rear discs and pads for '99 IS200 from an aftermarket trade parts dealer
He supplied me with vented discs for the rear
When I queried he stated that they only supply vented rear discs for my model - he showed me the book confirming this
I have spoken with another parts dealer, who states the same
The discs are the same size, thickness as the solid discs
Is this right - will it make any difference?
vented discs for the rear...............hmmmmmm,never seen or heard of this, can you get a picture and make
Checked with Lucas too - they only supply vented rear discs across the IS range - very odd
I got aftermarket (patten) part discs for the rear of my IS and they were solid.
:blink:
The vented discs are completely identical, but about 1mm thicker, but my ones are kinda worn anyway.
Will it make any difference??
All the rear discs i have seen for them have been solid too!!??
SPOOKY
I've struggled to get any rear discs..........let alone vented ones :duh:
Due to lack of technological knowhow a pic might be difficult
I am unsure as to fitting them in case I need to take them back
I have been told that vented would be better - I shall let you all know, if I don't die going round the first bend........
SPOOKY
want some Brembo`s?? :winky: :whistling:
ARE THEY REAL bREMBOS, THERE ARE ALOT OF "fAKE" BREMBOS AROUND AT THE MOMENT......
They should be dull machined steel, not the coated stuff, also the box is a dead give a way...........
not that im saying your selling "fakes" scott :unsure: .just that 99% of the ones ive seen are fake.
not that it really matters there all made from the same blanks anyway, just a different manufacturing process
Drilled/grooved is a bonus because.........................
drilling a brake disc does nothing other than weaken the discs structure..........fact
COST??
pm`d
Share it with the rest of us then. :winky:
£200 per pair.. regardless of front or rears.. ( All drilled/Grooved )
Cheers Scott.
