Hello,
For all you out there who have fitted an aftermarket stereo, what did you do with your heat seat switches? Cut the new adaptor & fabricate holders for the switches??, or relocate the switches?
The unit I have has a 'pocket' where the switches would normally be located. I could mount my Geodesy in the pocket, and maybe relocate the switches just infront of the lighter socket..... suggestions? I did also consider adding a computer controlled switch to my carputer using a relay, but this seemed a little excessive:)
Cheers
Damian
