OK,
How about 4 top quality flush fitting reversing sensors for £135 + P&P ???
Easy to fit (1 or 2 hours max)
drill 4 * 22mm in your rear bumper, thread the wire through.....connect to control box connect to reversing light attach speaker to underneath of rear parcel shelf........bingo.......
could be the bargain of the century.......... :P
Those of you wary of fitting :blush: I may be be able to arrange this as well at a reasonable cost.
interested ? email me at prolexuk at ao'ell dot com
sounds soooo good. can you hear it over the standard beeping tho?
Coz its pretty damn loud. but i sure could do with a set of these
how do these compare to the quanam ones
other than being half the price
sound good to me
sound good to me
You mean Quanan ones are half the price :unsure:
i'm definitely interested -
pls guys, NO comments about women & parking!! - it's hubbie that has the probs, not me! :rolleyes
need to be colour coded tho & probably fitted too...
Can these be fitted to the front aswell?
They can indeed. But you'd probably need a switch to switch them on when parking as the reears work when current is going to the reversing lights.
Hope that helps
Sometimes the metal bumper bar can cause problems with these systems although the web site does say it works with a metal bumper.
Rodders has this type of device although I think his one uses the actual bumper bar as an aerial rather than the foil tape to stop any problems with interference.
The 4 kit has a digital display - so how do you see it if it's mounted under the rear parcel shelf ?
It bleeps as you are about to hit the immovable object :whistling:
