the a/c panel looks complete in the flesh,, i think i will need to get the centre and right hand button centres lit up a bit more.
have a look as jae sunday,,
the TRC and heat seat switches are pretty easy to do, 10 minutes a piece.. even you could do it.. its a matter of sodlering an LED in place of the bulb. and adding a resistor in line on the 12V wire in.. i could do this mod at jae for you..
the TRC and heat seat switches are pretty easy to do, 10 minutes a piece.. even you could do it.. its a matter of sodlering an led in place of the bulb. and adding a resistor in line on the 12V wire in.. i could do this mod at jae for you..
That will be great Paul, also will bring spare air con panel willl you take that home and do the blue conversion for me matey?
  • 4 weeks later...
UPDATE.
A perfect plug and play solution is almost upon us..
Have a look at this A/C Panel, this was achieved using just three 5mm LEDS..no soldering just plug and play, an orange colour was used for this test..
The Current solution has 25 3mm leds soldered in place, plus the fact that you loose your panel for a few days..
Next to do is the speedo cluster,, a spare unit is currently winging its way to china to be worked upon, so please hold tight folks...
Dave
cheaper than current, and time frame.. not long.. bit bague i know,,but the cluster is off in the next day
:whistling: me i will have 1,2,3,& 5 please in Green :winky: should go nice with what i have comeing
:driving:
